1 - 2 of 2 Posts
I am planning to use my PC with a Sonus green pad for the all in one, and a blue pad for the sealant/glaze. Of course I'll buff everything with a MF cloth when I'm finished.
Reason I ask is that I have not used this product before, and have heard conflicting application methods. What did you do to achieve the best results?
Not sure what the Sonus green pad's level of cut is. I use Lake country pads. I've used a white polishing pad without any problems. I use a small bead along the perimeter of the pad, spread it on the panel before turning it on. Usually at speed 4-5. I'm using a 6" counter weight and backing plate with 7.5" pads. At speed 6 I get a little too much vibration. Will be switching pad sizes one of these dayz.
1 - 2 of 2 Posts
