1 - 20 of 45 Posts
SIR Bound....Slowly
Discussion Starter · #1 ·
K guys im gonna be droppin my accord in a month or two and i need to know the best way to change out the springs. I got a set of DZS Motorsports 2.25 In. Lowering springs i wanna put on.. I heard a way about jacking up the spindle, unbolting everything, then lowering down the spindle and the spring should come right out, and there is the other way with getting a spring compressor and doing it like that.. what do you guys think? Also im gonna need a camber kit.. can anyone suggest a good set to buy for the 2.25in. drop? and some good struts too.. im rollin on 18's just to let you know if that may make a diff.. Thanks
Shifting 5 Gears Baby !!
get an R-1 camber kit - like 50+-$ on ebay
they are just what u need to adjust 2 degree camber
and get a spring compressor / rent one etc - much much easier
SIR Bound....Slowly
Discussion Starter · #3 ·
what about struts? and is the degree you can adjust the camber at the same amount as you lower it? or whats the ratio? cause if its the same id need more than 2 degree's? Sorry cowgod and everyone else for askin so many questions.. You will be gettin sick of me soon probably.
the Lost Sol
haha i think he meant shocks
my camber kit has two adjustments 1.5 and 2 degree
I set it for 2 degree and did an alignment and it was fine
if you plan on using aftermarket springs, you'll need to upgrade to aftermarket shocks. I went the cheap route and score KYB GR-2 ( more less a stock OEM replacement ) and they have not given any problems at all
my suspension setup is very smooth and stock rebound if there are any bumps so it's comfortable, a smooth transfer of shock travel vs coil spring rate
the Lost Sol
nice pix mr cow...altho it doesnt lo0k like a 3" drop hehe ... i like the 1st pix rims better than stockies..:up2: ..lo0ks good
I don't want to be a pic whore, but trust me it's close to 3"
this is stock suspension
at the dealer before I bought it - stock suspension
slammed 3" first summer I had the car with adjustable sleeve coilovers
on a joyride with a group of friends - GR-2's with stock springs, was ready for winter
last summer with tein s tech springs matched with the GR-2s
a pic the day I got my car back from the mechanic after the swap just completed
SIR Bound....Slowly
Discussion Starter · #11 ·
ok nice pics cowgod.. jeez there is such a difference between your car and mine.. just by a year.. So then 2degrees would be fine for a 2.25 drop..Cowgod do you change out your springs every year for winter?
yes I ran it dropped once for winter, but I was a snowplow and damaged a lot of parts
it's not worth it to be dropped when we get 12-20" inch snow falls and then it turns to ice ;)
SIR Bound....Slowly
Discussion Starter · #13 ·
Well im in Indiana in the states.. so i dont think i get as bad of weather as you :) Isnt that kinda a pain to change em out twice a year?
no because then it gives me time to inspect all the parts associated at the same time ;)
SIR Bound....Slowly
Discussion Starter · #15 ·
makes sense...well, i guess if you've been doing it and you have all the tools and time then it wouldnt be a pain..
If you are going to go 2.25 inch drop then you might need some rear camber adjustments. My car when lowered 1.5 inches or so needed some rear camber adjustments for about .3 out of alignment but the front was just fine. Others have had no problem with camber on the 1.5 inch drop. Can't tell you why, I haven't the slightest idea. I do not know of a brand that is worth the money so maybe someone on here would know of a good brand?!?! Something to consider though definitely before you go all out. Also if a bolt is stuck and you try to pry it off and it isn't coming off be prepared to stop and take it to someone with air tools :) I learned that the hard way... :(
I dont think things have ratios as much as it is trial and error. It all depends on each car really and you will probably need to talk to whoever is doing the alingment and they should be able to let you know a little more on what they are going to need to give you even tire wear.
1 - 20 of 45 Posts
