Status
Not open for further replies.
Pilot & Accord
'03 Accord V6 Coupe EX Auto.
1. 14400-RCA-A01 BELT, TIMING (197YU20 VE-501) (UNITTA)
2 They list 3 of them... which one do I pick? (probably the RCA)
a. 19200-RCA-A01 WATER PUMP
b. 19200-RDM-A01 WATER PUMP
c. 19200-RDM-A02 WATER PUMP (AISIN)
3. 19222-P8A-A02 WATER PUMP GASKET
4. Is this the drive/accessory/serpentine belt? Anything better than that?
a. 38920-RCA-A03 011 BELT, COMPRESSOR (MITSUBOSHI)
Add them up. Shipped to K2G 5J8 Ottawa Ontario Canada
Tony, get the TB tensioner and idler pullys as well, they are usually replaced at the same time as everything else you are getting. PM me if you get stuck doing the TB change.
Pilot & Accord
I get an error on your SSL security certificate. Sorry can't proceed.
Pilot & Accord
Hi Paul... putting the parts list together for this job is giving me a headache !!!!!! The Haynes documentation is specific enough to do that without too much trouble. It just takes time to take everything out, clean stuff and install. I have the time !!!
This is the list I get from the basket at Ganley
  • Timing Belt
  • Stopper (Tool used to hold the Belt Adjuster)(1998-2002 Only) ... I guess I don't need that one since it is for the 6th Gen
  • Water Pump
  • 2-Cam Seals
  • Crank Seal
  • AC Compressor Belt ... is this the drive belt?
  • Power Steering Belt(1998-2002 Only) ... I guess I don't need that one since it is for the 6th Gen
  • 2-Complete Valve Cover Gasket Sets ... don't need that one either, already did the valve adjustment
Additional for 2003-2007
  • Tensioner ... I guess this is the auto-tentioner ?
  • Pulley
  • Idlepulley
Any comments on the above list?
Status
