Hi, thanx for the pm (2)That I am. Just send me a private message and we can speak about getting one made. Thank you and I shall speak with you soon.
Most indeed you do sir. What is your engine code?Apparently I need 5 posts (3)
Hey brother! Give me a shout on private messaging when you get a chance...new number...hope to hear from you soon.hay john I took 2years off bought new house but iam back. took the car to island dragway last week. About 36cars made $500.00 will talk soon.
Hey NSWDoc, I'm interested.Hey brother! Give me a shout on private messaging when you get a chance...new number...hope to hear from you soon.
LMK if you got my DM. The UI on V6P is quite... outdated least to say. Doesn't show if it sent or not haha.Hey brother! Give me a shout on private messaging when you get a chance...new number...hope to hear from you soon.
Hello Matt. I do still produce these yet I am having an issue getting access to a CNC machine right now. I will give you an update as soon as I do so I can get one out to you brother.NSWDoc
Greetings! I would like very much to buy one of these from you - very sick and tired of removing my home made block off plate every time I need to pass inspections here in PA, then putting it back on.. and /or cleaning out the manifold passageways ARGHH!
I am having a hard time finding my engine code for my 1998 accord having a 6 cylinder VTECH
I see a 3 letter code (ending in A) to the left of the EGR , in the same area but more to the front I see ///// marks
Hopefully you still make this.
Thanks
This is a neat idea can u make one for my 2000 Honda accord v6Well, not exactly, but damn close enough. As we all know the EGR system robs some power by injesting hot/dirty exhaust gases directly back into the intake. We can't remove the valve without throwing a code and we can't block it without throwing a code. If we block it the ECU throws a "Isufficent Flow" code as well as the ODB emissions monitor will show error since the ECU actually detects the lean out caused by the EGR opening and flowing exhaust back, and this is the key, the ECU does not care weather it is hot exhaust or cold/clean intake air. So I decedied to machine out a EGR Bypass Adaptor that allows us to connect eaither a breather filter or a hose connected back to the breather fitting on the intake. I just came back from a 50+ mile test drive with no codes thrown and for good mesure before I left on the drive I reset my ECU and emmissions monitors after the drive I checked and the EGR emissions monitor was happy with the bypass, so this will not effect passing emissions, and probably will pass visual if you hook a hose back into the intake.
Thanks to Shonda for jogging my brain and getting me to think of this.........
This will also work for 6th gens and K-series although the bypass connection is in a different place for Ks......
