1 - 2 of 2 Posts
J35 _ 5-Speed A/T
They will bolt right up and the valves WILL clear the J35A4 pistons. One of our members has done it - MONEYPIT.
Now this is confirmed using an OEM cam, the J32A2 cam. IF you go aftermarket cam with a higher lift, I suggest you "clay" the piston to verify clearance (valve to piston).
1 - 2 of 2 Posts
