I am getting driven crazy by this, been forum searching for over 5 months about this and can't find anything.
Ignition components were replaced, all of em. Valve clearance was done, egr was replaced, new cam shaft sensors, vtec cleaned out and new orings, newer MAP sensor, compression is great in all cylinders, oil is at full, injectors were verified spraying and strainers were cleaned out, fuel pressure is fine when tested after egr replacement. Cheese and rice my guys idk what to do. I'm thinking clogged cat partially maybe but vacum tests ruled that out yet some say under load it can be a problem but I can't see anything too unusual on vacum reading under acceleration. It's a 99 honda accord v6 3.0 EX trim with 212k miles. Mechanical timing seems on point. I have the service Manuel pdf and I have gone down the checklist, maybe vtec isn't throwing a code and it's really that? I did the valve clearance three times to be sure it's not that. Primary o2 sensor replaced.
