1 - 4 of 4 Posts
So, i've been trying for a couple weeks to get the info on the CL-s sway part #'s and I can't even seem to get an answer on what year it is that fits. Can't even find a post on it.
Anyone got that info?
TIA
Rear sway bars from a 2nd gen cl-s or a tl-s 99 to 03 will fit. I do not have the part number. The size you are probably looking for is the 19mm. I am using the 19mm on the rear of my 03 v6 sedan and the reason I don't have the numbers is that I got mine from a guy who put Neuspeed bars on his cl-s. The front bar will not fit a 7gen accord. search the site under sway bars and you will find a lot of info.
Tim
346hp/300tq @ 4psi
yep, cl-s 00-03 is what you need. i was also looking to get the cl-s sway, but opted for the thicker tl 20mm. still had the part #'s laying around here you go,
1 ea 19mm bar #52300-S3M-A01
2 ea 19mm bushings #52306-S0E-015
2 ea brackets #52308-S3M-A00
those are all the parts you will need, hope this helps
yeah, I searched quite a bit around and couldn't find it for one reason or another.
Thanx a million 04accordcpe. You're a life saver.
1 - 4 of 4 Posts
