2008 Honda Accord V6 EX-L Coupe
Discussion Starter · #1 ·
For awhile my Accord V6 has been needing a clutch replacement and it finally started to act up. As a replacement I decided to go with the Luk Clutch Kit and Flywheel. It is the cheapest clutch replacement that’s basically an OEM alternative. The only things I am not using from the kit is the throwout bearing. I opted to go with the OEM throwout bearing just to be safe and while it’s being installed I am also getting the Rear Main Seal replaced!
As a bonus, my RV6 HFPCs are being installed at the same time so when the car is back it’ll be more powerful than ever!
