Does anyone have pics of component set ups in their 2001 accord coupe? I got my tweeters to fit in the stock space but I need a install how to with pics to see where to mount the crossover box.:confused:
I custom mounted my tweeters but the stock position isnt bad. Most componants you will have to build a wooden ring as a spacer as the magenets will not clear the windows when they are down. As far as the crossovers go I have mine mounted in my trunk because I am runnning an amp, a good place for you to put them would to be up against the outer door shell or on the inner door fram with some velcro or tie straps depending on how big they are.
