Discussion Starter · #1 ·
I have a rare set of rims which will fit:
98-02 V6 accords
03+ Accords
Perfect offset for the above applications.
Size Specs: 20 x 8 f/r
Bolt Pattern Specs: 5x114.3
Tires: Nitto 555 - 225/40/20 - 90% tread
**Rear lip is larger than front lip for a staggered look, HOWEVER, the actual rim width is the same** That means you can still rotate the tires between the rims but still have that expensive look of custom staggered rims.
One lip is bent (repairable)
One other rim has curb rash
The center of all the rims is in like new condition.
Also keep in mind, this is a custom 3-piece wheel. ALL YOU HAVE TO DO IS REPLACE THE *ONLY* THE LIP AND THE RIM IS LIKE NEW.
Originally paid $3000+
Only used the rims 4kmiles.
Asking $2000 for a one-off custom set of rims.
