1 - 11 of 11 Posts
I tried "search" but no clear answer.
I replaced the bulbs in the dash with White LEDs, and there I had,
bright blue color.
Is there really NO WAY to get "White" color with stock dash face?
What makes the white color to turn into blue?
Is it the film? if so, have anyone actually tried removing it?
One more question..
I remember reading a thread about changing the needle to red color.
I can't clearly remember how he did that.
Is there any way that I can make the needle really Red (and bright)?
Won't the painting on the needle make it deemer?
Old Member
there is a blue filter you need to remove that in order for it to be white.
First of all you really cant get a true white with LED's because its impossible. You can come close, but there is always going to be a tint of blue.
As to acheive the blue color you need to swap the bulbs in the back with blue leds
The needles can't be repainted, if you want red needles you are going to need to swap the whole gauge face with an 01-02 cluster
Baaaaaaahhhh!!!
I read this thread b4...How did I miss that huge explanation on
removing film...It sounds really hard...-_-....
I might just stick to light blue color...-_-..
Thanks for the help~
Old Member
does this look white or blue to you?
image courtesy of Knightryder
oh yeah and no one is getting owned here obviously all you need to do is remove the filter so you can get white beam to shine across, case closed. :D
Discussion Starter #9
I love the color of his CD player...
However, his gauge still seemed to have slight blue color tho~
......are you blind? thats blue!
1 - 11 of 11 Posts
