1 - 19 of 19 Posts
J32A2 + SC + Meth AV6
I told Comptech that I need a CL-S High boost pulley and they said I'll need a new belt also. I remember reading something on here where people were just using the one that came with the original boost pulley. Maybe he thought I own a CL-S 6-speed because I asked for a CL-S HBP. So can I use the belt that originally came with the Accord normal and high boost pulley?
The part number he gave me is: 350-058 Belt, CL-S 6-speed
I'm pretty sure we can use our own belt (AV6 belt). He probably just got me a CL-S belt b/c he thought I own a CL-S because I asked for a CL-S HBP. Too bad I don't have my Comptech checklist sheet so I can check the Accord belt part number. Any CL-S HBP owner change their belt to the CL-S belt?
530whp soon
Try any autostore for:
GOODYEAR Gatorback (Poly-V) part # is 4040245 (24.5 inch long) otherwise also know as 4PK0620 which is about $12-14.
there is not much of difference between 4040252 and 4040245. both would work because you still need tension it with adjuster.
530whp soon
I use 4040245 even with MAX BP (blower) + CL-S HBP.
Tried 4040252 and it was too long and slipped. BTW, the difference is 24.5 inch vs 25.2 (last 3 numbers indicate length).
530whp soon
i just looked at my belt and its 4040252/4PK640. it seat on pulleys just tight, it can be shorter, but i don't see reason (for me) to buy shorter belt.
02AV6 said:
I'm curious if changing to 4040245 you might see better results with thermoblock spacer which definately keeps the IM cooler and allmotor tested it with 10* drop before/after. Just make sure belt is tight and as mentioned tried 252 and changed to 245 eventually.
i tried to install thermoblock gasket, but throttle body gasket doesn't work there. it puts IM elbow too far out to joint it with supercharger elbow.
530whp soon
Correct, I heard SC guys used only manifold spacer. Unfortunately, I cannot use one since I won't be able to close the hood. This mod + Mugen cooling mods = :up2:
1 - 19 of 19 Posts
