1 - 15 of 15 Posts
NSX dreamer
Prices listed do not include shipping.
01 Accord V6 Auto Shifter Assembly...Great condition. Comes with all solenoids and the wiring is not damaged/cut at all. Trim ring has a small scratch on it in bottom right hand corner and is missing the shift lock release hole cover. Everything else is pretty mint. I field stripped this thing and downright detailed it- This isn't some dusty, gunked up junkyard unit on ebay. Also, the shifter column has already been shortened for better looks when using with an aftermarket shift knob, but this doesn't interfere with using the stock shift knob because I didn't cut so much off that it interferes with using the stock mechanism and screw holes.
Sold as an assembly with trims for $50, shift knob separately is $40, buy together for $75.
Brand New OEM Genuine Honda Center caps (4): $50. They are the top row. I bought these for the RSX wheels I put on my 6th gen, but they were too small, so I bought the bottom row. I pictured both for size comparison. They were special ordered so I could not return them, but I believe they are Civic fitment. They are definitely not 6th gen Accord fitment. I have shown measurements so you could see if they fit your wheel. Since the H can be removed, this would be a great cap to use to add an "OEM+1" look to an aftermarket wheel, especially if its not silver since you can paint the cap separately (assuming the cap fits) to match and then reattach the "H".
Brand New Ichibahn Automatic Shifter: $40. Recieved as a gift but I decided to swap out my stock shifter for a gated CL unit. Anyway, this has a high quality metal and leather construction..Has a nice heavy feeling in the hand, I imagine it shifts with authority.
any chance your located near 19120? (philadelphia)
want to buy the used 6th gen center caps
and the discount tire direct lugnuts
NSX dreamer
Pm'ed..
Thread update...discount tire direct lugnuts are no longer available..decided to install them on my own car..funny fact..the box info on the side turned out to be completely irrelevant: the label is for lug bolts for a BMW!
NSX dreamer
Lol well check this out, i just tried seeing how a dollar bill compares with it..using the face side, from the left end, the center cap reaches down to the middle of the "N" in "ONE" in "ONE DOLLAR"...so give it a try, hopefully you have better luck finding a dollar lol. Try to not let your neighbors see you polishing your rims with money. :crazy:
1 - 15 of 15 Posts
