Weather Stripping:
i been wanting to replace my driver side weather strip and one in the bottom part of the trunk area
both are much easier than i thought, basically just pull them off, i used 3M weather stripping adhesive in Yellow since the old stuff looked yellowish...it does come in black and i believe clear
https://www.autozone.com/sealants-glues-adhesives-and-tape/weatherstrip/3m-yellow-super-weatherstrip-and-gasket-adhesive/196147_0_0
the one on the actual door itself is held on by a bunch of tabs and way more involved than simply pulling off, putting in some adhesive glue, and installing the replacement
Acura Door Sills:
since i was in that area, i'm not sure if someone has done this before but hopefully my experience can help someone in the future
so if you don't wanna spend like $200-250 on genuine JDM door sills, the Acura OEM Door Sills from the:
https://www.ebay.com/itm/JDM-Sill-Sills-OEM-for-03-07-Honda-INSPIRE-ACCORD-UC1-UC3-CM5-CM6/201762979935?ssPageName=STRK:MEBIDX:IT&_trksid=p2060353.m1438.l2649
Acura TL 3G & Acura TSX 1G
are direct replacement for the Fronts on the Honda Accord 4 Dr. Sedan. Meaning that the tabs on the backside match up and snap in perfectly
There's 2 different patterns, the horizontal lines from TL and the square pattern from a TSX
they can be had for fairly cheap at local junkyards, i think i paid $20ish for the front x2 and rears x2
they can be had on eBay for like $35ish
took them to my Graphics guy and got rid of the pesky ACURA logo for $15 for background and lettering w/out install
if you want the Rears too, they are NOT a direct fit. basically both the TL & TSX have a curve that the OEM Accord ones don't
TL is top (blk) & TSX (grey) bottom. TL has a bigger curvature
i went the simplest route i could think of, remove the Metal plate from the Acura TSX ones and transfer them to our OEM ones. really simple, bend back the metal tabs:
its not perfect but you can bend the top tabs straight on to the OEM ones and drill holes for the bottom ones:
covered the pesky Acura Logo:
total cost was $35ish for 2x Acura TL front Sills & 2x Acura TSX rear Sills + $15 for the vinyl
its not completely smooth since the ACURA lettering is etched but i like them so far
if you wanna take them a step further, this thread could help:
https://acurazine.com/forums/third-generation-tl-2004-2008-93/diy-illuminated-door-sills-921417/
