1 - 10 of 10 Posts
Discussion Starter · #1 ·
new the the site and loven it....where can I get a good set (f&r) drilled and slotted rotor without having to change calipers?
Are you a 6-speed manual or automatic?
Are you getting slotted and drilled for performance or just looks?
The Jester
Have heard slotted for structural stability, some looks, and to prevent glazing of the pads for performance riiight down to the caliper.
Holes means a crack has to go 1/4" between holes instead of 3" from edge to edge of the rotor. If you intend to use them for anything intense, I would go slotted if you are set on non-blanks.
Otherwise, Brembo blanks seem to be the most common OEM replacement. Either paired with EBC or Hawk pads will amaze you at stopping times and pad life.
1 - 10 of 10 Posts
