1 - 11 of 11 Posts
I have a few questions...
1. I know to add a sub/amp to your stock headunit you can use the JL Audio Cleansweep. But will that work if you have Navi?
2. About how much would it cost to have a custom box made like this?:
3. My friend is selling me his Rockford Fosgate Punch 325.1 Amplifier for $50. Can someone explain some of the specs of this amp for me? Is it a good amp for wiring up a 8 or 10" subwoofer?
here's the link: http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=18395
and here's a pic of the amp:
someone please help me cuz i'm a bigtime noob when it comes to audio systems...
Your V6P Snake Champion
Well are you going to be making this box yourself. If so it will only cost you around 50 dollars. Just get some resin and fiberglass mat at your local home depot.
Heres the box me and my friend made.
neeeeeeeeeeeeeeeeeeeeeeel
i am looking for a single 10" box too like that.. any one can make me one? i also wanna mount it on the lft side of the trunk..
XCLUSV
nice to have a custom fitted sub-box. also nice to know someone who could make it for you for a very good price. if not shops charge alot to do it.
Go to the top shop in your area and ask to see some of their work. If you like the work negotiate a good deal, normally I would charge 300-400 for something like that. Fiberglass work tends to be a money loser the bigger the job, but this is small. Shop around.
hey oswhiteboy, is there a step-by-step diy on here on how to make a custom box?
Discussion Starter #9
Champaned_out said:
what kind of sub are you trying to match with the fosgate amp?
i want either a 10" JL Audio Sub or a 10" Rockford Fosgate Sub
I just made a half wood & half fiberglass for the first time reading stuff online and its definitely do-able if you have the patience and the tools. But I would have to say it would cost less than $100. I had an excellent resource in my friend who works part time for Car Toys installing stuff. He guided me through the entire process, giving me tips and what not. He sometime would insist on doing it himself, but I'm proud to say that I did everything by myself. My advice is to try to use much wood as you can, I'm so glad that I did. Less fiberglass = less pain in the butt. I don't have pictures of my box cause I still need to sand the bondo and put carpet on it. Now that I know, I can do more fiberglass projects on my own and help friends build theirs. Just read and do some research and put your mind to it, the box is yours.
Here are two excellent DIY on fiberglass that I used to build my box.
http://chris.pfharlock.com/glass/index.htm
http://www.gadrivers.net/~dwicker/fiberglass.html
keepin' it OG
i'm gonna make myself a fiberglass box too. i have everything except for the rings. none of the local shops here that i know of have it, so i'll probably buy some on ebay i guess.
1 - 11 of 11 Posts
