If anybody here is brave enough to tell me how to change the flywheel on the 03 accord coupe 2dr 6mt. i would really apreciate it. Thanks :help::up2:
My guess is remove intake, disconnect tranny, slide axles out of tranny, lift tranny up....
Once you can get to the clutch/flywheel, use a 12-point 12mm i believe on the pressure plate bolts (alone the outside edge of clutch) to move that. remove clutch disk, use an impact on the 8 17mm or 18mm 12-point flywheel bolts. reverse process.
