Question,
I have a 2007 Accord V6 6 speed coupe. Last year I installed the OEM fog light kit. Everything was working fine but now my LED bulbs that I use are barely getting power at all. They are dimly flickering. OEM button is lit up showing that it is working. Had my friend who knows about electricity check to make sure that the bulbs were getting 12 volts and they are. Also getting a good ground. He thinks that it might be an issue with the OEM button. Is that possible? Or a relay issue?
Checked the bulbs and they are ok by plugging them into a 12V source!
Any help would be greatly appreciated!
I have seen cheapo LED bulbs go out like that. When you plug them in they look like they're working but in reality they're not nearly as bright as they should be. Try a cheap H11 bulb from walmart and see if that works.
Could be a wire short. Check the wires at the switch for continuity, ground etc.
If I remember correctly the OEM kit makes a connection to the underhood fuse box, I had to remove the box and make a connection underneath, check that too.
