Ok well my car came with the OEM glass foglights. I believe it was the last couple rainy days, but my foglights stopped working. I pulled out what seemed to be the fuse (there was no marked fuse for foglights) but a 10 amp in a spot I found from another thread. And that seemed to do the trick but the foglights turned off immediately after again. The fuses aren't burned but the foglights just won't come on. Is there maybe a relay that I'm not aware of? And yes The switch works and lights up.
Thanks in advance for any advice!
just do some basic voltage testing. Have you checked to see if there is power at the bulbs? Its most likely going to be a fuse or switch
Yea I haven't had time but hopefully today I can really get in there. There is no relay for the foglights though? Just a fuse?
The name is Z
There is a relay for the fogs. If OEM, the relay is mounted on the STB on the DS near the strut mount. What likely happened is your lenses caught a crack from road debris and the water is shorting them out which pops your fuse.
dont deviate
good info. might be time to replace my broken lense fog.
