Banned
hi how easy or hard is it to take out the bulb...i got some blackhousing units and i dont want that amber parking lite...i wanna rplace it with some white/bluish 194 bulb...is it hard to rplace? im not a handyman type of a guy...also is there side marker lights for v6 2001 coupe thats white in color but flashes in orange??? thanx if u can help me
are you talking about the turn signal bulb ? or the little running light under the low beam ? both are pretty easy to get to the running light under the low beam/high beam, you just have to reach behind your headlight assembly and turn to unlock, the turn signal on the far end you have to pull back a little bit of the black plastic wheel well material. look in your manual it'll give you a better description on how to get the bulbs out w/o having to take the whole assembly out...
