1 - 20 of 25 Posts
14.58 =Quickest Gen7 auto
Compared to the rear one, yea, it'd probably be considered much more difficult. In order to swap the front bar, the front subframe has to be dropped.
Stoner2003 said:
Has any one install the front TL sway bars on a V6 sedan can you let me know if is hard to install
I let Alan Cox here in north atlanta do it for me, so it was easy. You have to drop the front subframe to do the install. If you have the tools you can do this. The shop took about 45 minutes for the install. I did not need an alignment after the install. I am also glad I did this mod. :banana:
346hp/300tq @ 4psi
you got lucky, from what i hear, it throws your alignment off and its hell to correct.
sway bar would not throw your alignment off...
personally i like my car to be a little bit on the oversteer side, but not too much...so thicker in the back, and same up front...
Not the sway bar. :p
Dropping the subframe typically puts it out of alignment. If yours isn't, I think you just got lucky.
But I don't know of it being "hell to correct".... I think an alignment can usually fix it up. :gotme:
i never changed my front sway bar...only the rear...and yea i guess, if u mess with more than just the sway bar, u'll usually need an alignment...but either way, you should get an alignment done every year just to make sure ur car is travelling straight...saves a lot on the gas
Banned
From what i heard the front sway when changed you will need to do a front alighnment. Also since our stock bar is like 25.5mm , 1.5 2.0 mm more isnt going to do anything for you.
Waste of money if you ask me. It has been proven by Comptech through various tests.
Use the extra 100 bucks and buy the Comptech SS for a 6MT or a new stainless steel exhaust.
The car is pretty much netural now for me , with my 27mm sway by comptech and stock 25.5 mm front bar.
Most people on here or practally everyone who installed the sways did either the rear first or both at the same time so no one can say that the front sway makes a big difference. Also it is a known fact that our stock sway is way way too small. Its like 15mm . Which causes instability when changing lanes and at high speeds.
27mm-15mm is a big difference :)
Install the rear sway which is much easier and you will notice a huge difference.
^yes, the rear sway bar does infact make a big difference...the accord's in canada come with 13mm stock rear sway's..and changing to the TL made a difference, i wouldn't say made a big difference...because my other car (acura 1.7EL), i changed my rear from 13mm to 22mm (rsx-r) and it made a really really big difference...i guess it depends with vehicle and weight...
The issue on the couple extra mm up front (for some at least) was the huge difference in the rear, but possibility of now getting too much oversteer. It's about balancing it out.
I beg to differ on your assertion about the front sway, I did 6 speed tl front sway several months after I had installed the rear 6 speed sway. I really did notice the difference after the install of the front. I previously had a type s tl and after the front and rear sways and front strut tower bar was installed on my V6 sedan the handling is getting close to what I had with the type s. Certainly need to upgrade the springs and shocks to further narrow the gap but, well that will be another day. The real question based on my observed differences between front and rear sway bar upgrade is would I do the front sway again and the answer is yes I would. If you live in atlanta area you can drive my ride and judge for yourself :cool:
Banned
Well if that was the case howcome comptech never released a front sway :)
346hp/300tq @ 4psi
27mm :eek: are you talking about the rear sway?? if so, i thought the comptech rear was only 22mm. that is almost double the stock 14mm. i only have the 20mm tl rear and i felt a difference.
Banned
I meant 22mm
probably because there is not a big enough market for it. I would counter your question, why did honda build it if you did not need it - at least in a performance type ride??
Maybe, also comptech sells to a lot of diy'ers and this one is not really an easy diy.
However, to be honest comptech would have to answer your question. I can only say I am glad I installed the 27mm front sway and I would do it again as I did notice the difference.
finally this subject is not worthy of debate, if you do not want to do it do not do it, if you do then go ahead. all mods are subjective my only point in this thread is I installed the front sway and I think it is worth it. :) :)
Yea werd....I like mine...except the fact that my car has been impossible to align every since. :mad:
every lil thing changed on yer car will make a difference in some way or another..
or else why would F1 cars etc. race cars spend so much time on tweaking thier ride to make it handle and go .10 faster than b4..
_
that is the whole point for forums and asking questions, to find out things from others. this subject obviously is worthy of debate, hence the thread and responds.
i am looking to do this since (like many others) i am in a quest for a better setup. i have already done the rear tl bar as well. but like some people have said, it is a beeotch to diy, alignment problems, and cost vs. actual gain. some say yes, some say no.
i know it has been said before, but i couldn't find it under search, if anyone knows offhand or knows the link to that thread...
what are the diameters of the auto v6, 6spd, and tl front sway bars?
The Accord 5AT & 6SPD and the Acura TL 5AT use a 25.4mm hollow bar with a wall thickness of 4.5mm on the front.
The Acura TL 6SPD use a 27.2mm hollow bar with a wall thickness of 5mm on the front.
This works out to about a 55% increase in the stiffeness.
For comparision the Accord V6 5AT & 6SP use a 25.4mm front.
On the rear they are Sedan 13mm
Coupe 14mm
On the Acura TL 5AT front 25.4mm
rear 17mm
On the Acura TL 6spd front 27.2mm
rear 20mm
Tim
so what is a better setup if u have the comptech rear sways? go with TL 6sp or auto front sway bar?
1 - 20 of 25 Posts
