1 - 20 of 21 Posts
Fast at Last!... kind of.
Selling a set of FOUR (4) 5x114.3 CNC-machined hub-centric 5mm wheel spacers.
These are a direct bolt-on and will not cause wheel vibration at high speeds. Also because of its construction, unlike generic aluminum spacers, will not compress over time.
$55 USD + actual shipping calculated based on your location
Paypal +3.05% accepted.
Discussion Starter #8 (Edited)
Center bore is 64.0.
No these are not bevelled, but the height of these allows the OEM bevel to still work. Also, I should point out that I used hub-centric rings with my wheels with these and I did not experience any wheel vibrations at any speeds.
you talking about the studs... you should be safe w/ your stock studs on a 5mm spacer... anything bigger you should get extended
hmm. interested... just gotta make sure they fit mine..
1 - 20 of 21 Posts
