A. What is for sale/trade (model, specs, etc.):
These came off of my 2004 coupe. Aftermarket, black housing Depo headlights retrofitted with TSX projectors. Will come pre-installed with Osram 66240XNL D2S bulbs (4200k color temp) with roughly 3 years of use. Will also come with Denso ballasts which plugs directly into your factory harness. I've used them this way for 3 years without issues but you're free to use your own auxiliary harness with fuses if you want. As a bonus, the "kit" will also come with Triton V3 amber/off/amber switchback LED turn signal bulbs. They blink on/off during use instead of dim/bright/dim. Unfortunately my tap for one of the turn signals has went bad but can be easily remedied with some soldering (see pictures). The turn signal relay to prevent hyperflashing will also be included with the kit. This setup is completely plug and play.
B. Condition: Used, the headlight lenses are not yellowing but could use some polishing if you're particular about clarity.
C. Price/What you want to trade for: $450 picked up but can ship at buyer's expense
D. Location of item: Boston, MA 02115
E. Picture of item for sale / for trade / for free with a sheet of paper (i.e. verification slip) with the following on it:
Automotive parking light Hood Automotive lighting Automotive tire Motor vehicle
Automotive parking light Automotive tail & brake light Vehicle Grille Automotive lighting
Gas Composite material Nozzle Wire Electric blue
Brand new, sealed Osram 66240XNL D2S bulbs (set of 2). I bought these as a backup set but never ended up needing them.
B. Condition: Brand new
C. Price/What you want to trade for: $100 picked up but can ship at buyer's expense
Font Motor vehicle Automotive tire Automotive lighting Metal
Font Automotive tire Gas Technology Auto part
Liquid Rectangle Font Auto part Electronic component
OEM fog light harness and switch. This was originally a set from the sedan but I've had minimal issues with install and function on my coupe. I did have to zip tie the relay bracket to the strut tower bar but that was the only issue I ran into. Comes with the relay harness, relays, relay mounting bracket, 20A fuse, switch (and backlight bulb), switch harness, and switch ground screw. Everything but the actual fog light housings and fog light trim. Installation instructions will also be included.
B. Condition: Used
Grey Art Font Road surface Asphalt
Window Fixture Door Car Auto part
Brand new Morimoto XB Type H LED projector fog lights, 5500K color. Will fit all 7th gen Accords with the appropriate fog light trim. I bought these as a spare set because fog lights tend to get destroyed by road debris. Luckily I've never had to use them. Unfortunately I don't have the original outside packaging because it got destroyed during my move. It's a good idea to buy some PPF film and cover these before you install. Plug and play but you will need the fog light trim for you particular vehicle. Might fit other Hondas/Acuras also.
B. Condition: New
Motor vehicle Automotive tire Font Crankset Automotive lighting
Automotive parking light Hood Automotive lighting Automotive tire Fluid
