1 - 20 of 21 Posts
what does it mean by it fits without the trunk springs?
It's a better fit if you take one spring out, it matches with the curves of the rear panels. Having both springs makes the trunk sit a little higher then the rear panels. (1/5 of an inch or less)
Not only does it fit better, but since it is lighter then stock, with both springs on, the cf trunk opens fast and hard. Taking one spring out eliminates that.
180.00 pick-up, otherwise buyer pays for shipping which I assume won't be cheap considering the size of the trunk, not so much the weight.
1 - 20 of 21 Posts
