1 - 20 of 20 Posts
EDIT: Everything is SOLD! Thanks guys for the help & support!
So, selling my suspension wasn't enough for me to cover the loan so I'm forced to part the rest of my car and sell my retro :(
The headlights were professionally done by Customlightz using S2000 projectors, E46/A4 combo Shrouds, E46 M3 ballasts/igniters with 9006 plug, Nissan OEM headlight sealant and low gloss black paint job. I recently purchased a new pair of Philips D2S 85122+ bulbs (200 lumens brighter than regular 85122 bulb). Very sharp cutoff with adjustability.
Also selling a V6P.net Ground Kit custom fit for the V6 Sedan. All bolts, illustrated instructions, etc. are included. $40 shipped OBO (For more information on a ground kit see below).
What does a ground wire kit do?
A ground wire kit reduces spikes in electrical signals. All cars have electrical signals that go from all of the sensors to the ECU and then from these signals the ECU sends out signals that control the engine, air fuel, and other electrical components. When a good ground is not provided it allows for a spike in the electrical signals that are being received and sent out by the ECU. When this happens the signal is slightly modified causing the car to not run the way the ECU intended it to.
Although all cars already come grounded, aftermarket ground cable kits create a much better ground than OEM. A good ground wire kit will give a full and clear signal and remove most if not all of the impurities in the signals being sent and received. This will allow your car to run more efficiently which will allow for better performance. Better performance is most noticeable by a smoother idle, improved starting and throttle response, and no headlight dimming when you turn on the a/c or heater. A good ground wire kit will also stabilize the engine at higher RPM’s. Any improvements in fuel mileage and horsepower and torque will vary with each car.
The V6P.Net Ground Wire Kit is the highest quality kit on the market. Feel free to compare our kit with our competitors. There is absolutely no comparison. V6P.Net's superior wire construction, wire connectors and battery terminals create the best ground in the market. Our kits are custom made so there is no ugly round plate connector. Because our kits are custom made for each application, there will be a one-week delay before shipping so that we can make your kit in accordance to the highest quality standards in the industry. Our kits carry a one-year limited warranty and come with detailed color instructions on where to bolt the wires onto each vehicle.
Ground Kit DYNO: http://www.v6performance.net/forums/showthread.php?t=50738&highlight=ground+kit
PICTURES
pm'd
does the ground kit fit 4 cyl 7th gen?
so does the ground kit fit an 03 v6 coupe???
I'm thinking it would because I can't see a significant difference between an 03 v6 coupe and 04 v6 sedan but I can't promise anything. Send me a pic of your engine bay and I can tell you if it will fit.
1 - 20 of 20 Posts
