1 - 16 of 16 Posts
can't go lower...FML
bump for this guy. LEGIT. just checked this kit brand new pricing.
180~220 w/o shipping. Also, it's discontinued. I'd say it's much better than any kit out there compared to Suns or Buddy Club.
btw, the apexi logo lights up red =)
J35 _ 5-Speed A/T
double bump
Any car should see a little bit of HP/TQ gain from this ground kit. 1 member dynoed his V6P ground kit and it showed gains - check for the thread.
Since V6P may not be supplying us with a future ground kit, someone should pick this up, it's a good price.
People who are looking for instructions, all you need to find are the ground points in your car. Look up the installation instructions as the V6P grounding kit. I think the v6p kit has about 4 or 5 points. All you need is 3 points for the APEXi kit. if you have the tools, should take you about 30 minutes to install
Discussion Starter #16
This grounding kit has 3 points you need to connect to minus the power and negative terminal on the battery; alternator, engine block, and throttle body.
1 - 16 of 16 Posts
