1 - 20 of 21 Posts
J35 _ 5-Speed A/T
98-02 COUPE only C-pillar bar.
This is an extra one I purchased on the group buy from BOOM PLUS TOYS
$160.00 shipped to US addy only.
PM me if u wish to buy.
actual product is pictured in my gallery....
WHEEELMAN
J35 _ 5-Speed A/T
damnimballin said:
hey is this available still im interested...
The first interested party has passed on the sale.
I still have it for sale. $160.00 shipped, that price is my cost.
I will ship + insure via UPS to US addy. PM me.
Check my gallery for the installed product.
WHEEELMAN
Banned
so I gotta remove my rear panels around the seatbelts to install this? is there a way to put it in w/o removing the rear panels?
J35 _ 5-Speed A/T
.. i already had most of the rear panels, etc, already removed. Took little time for me to remove my own pillar OEM panels and install the c-pillar "bar".... i'm a noob on these Honda cars and mods so i can only offer my opinions.
As u can see the mounting bracket is rectangular and larger than the seat belt mounting round hole that is in the OEM c-pillar panel. Some cutting of the OEM panels is required to mount the square bracket for the c-pillar bar.
** I recommend/suggest that u actually remove it so you can make a clean precise, tight fit = customize = for your own or "show mod" application. Then reinstall the panels, seats,etc.... and finally the c-pillar bar/seat belt bolts. Unless your cutting/install skills are better than mine and my skillz are not hard to beat...lol. You could attempt to cut the panels w/o removing them.. A small Dremel could do it no problem.
My photos simply show how the bracket should be mounted to the "body" of the c-pillar. I felt this was important for safety so everyone knew how the bracket def needs to mount. It kinda fits two distinct ways..just feels more solid in the right position against the body. Sorry, i didn't use my panels. I actually had no need to reinstall those pieces at this time.
WHEEELMAN
i didn't need to remove any panels. worked fine for me.
Banned
uhh.. sooo.. do I or do I not need to cut anything to install this? also is the price negotiable? if noone else buys it? just curious.
Banned
i really dont c how this bar does anything for the handling. its the strut towers that stress under tight turns and bumps. if it the car was flexing from the c-pillars then ur car would be focked up.
Banned
your whole car flexes on tight turns, also on the coupe the seat belt brackets are only a few inches away from the top of the strut tower....
Banned
think about it, the c pillar is practially part of ur quarter panel. if this part of ur car was flexing then ur paint would chip, your windows would crack, etc. i honestly think it is a waste of money mod, otherwise i would have been the first to purchase one. rear strut bar on the other hand..... :D
texas is treatin me ok, too damn hot, i miss NYC weather.
vTecaznracer said:
i had to cut the rear panels to install this mod.
did you install it under the seatbelt like how wheelman had it? or did you install it under the gold bolt but over the triangular piece?
jinsoku.com
i installed it so that the bar would be connected to the frame of the car...so basically, the took the seatbelt off and installed it and then put the seatbelt over the end link.
i dunno but i've been told thats the incorrect way to install it and that it should go over the seatbelt and under the yellow bolt.. :confused: :confused:
J35 _ 5-Speed A/T
Discussion Starter #17
I dunno either, the directions i got were in Asian characters. It just made sense to me to install it that way.... it could be wrong. Im sure theres a phone number listed somewhere on the directions that came with the bar..can someone call and get directions for us....maybe,lol.
Bump for DRIVEN = still fo sale, but @ $160.00 = my cost is your cost.
WHEEELMAN
yeah i dunno. morris told me it goes on top of the seatbelt thing and not to the frame like how some people are doing it.
jinsoku.com
i guess i did it wrong. i just thought it would make more sense to bolt it to the frame since its a frame strengthening mod...oh well...
does it really matter how its on there..........i mean as long as it holds both sides together itll still work .......it just matters like on how you want it to look i guess
1 - 20 of 21 Posts
