1 - 4 of 4 Posts
I have lots of PowerBass stuff. You may not be familiar with PowerBass because they are a younger company, but they build the subs for Memphis ... so it is definitely a good brand.
PowerBass ES12DS - Sound Quality Loud (SQL) Subwoofer
12" Dual 2 Ohm Subwoofer
Power Handling (Rms / Peak):
600/1200 watts
Frequency: 20Hz - 500Hz
Sensitivity (1W / 1M): 94.3 dB
56 Oz x 2 Double Stacked Magnets
2.5" CCAW Voice Coil
Retail: $369.99. I am selling for $125 each, $200 for a pair. Boxes available, just ask.
PowerBass XA3000D
Specifications Model XA 3000D
Number of Channels 1
Output Power (14.4V) @ 1 ohm 3000 watts
Output Power (14.4V) @ 2 ohm 2000 watts
Output Power (14.4V) @ 3 ohm 1000 watts
Frequency Response 10 Hz - 400 Hz
Total Harmonic Distortion 0.05%
Signal to Noise Ratio @ 100Hz >90 dB
Input Sensivity 200mV - 6V
Dimensions (W x H x L) 10.51" x 2.56" x 20.87"
Look at the power supplies, torrids and caps
Benched at 2800w+ at 12.3v at 376 amps of draw at 1 ohm stable load. At 14.4v, 3500w. At 16v, 4000w. Drop the impedance and you start getting ridiculous power. This beast weighs 30lbs. Only a handful of amps actually put out more power, all for a lot more money.
Retail: $1600. Asking $800. $1500 for two of them. Amp kits available as well
PowerBass XA485
Specifications Model XA 485
Number of Channels 4
Output Power (14.4V) 4 ohms stereo 4 x 85 watts
Output Power (14.4V) 2ohms stereo 4 x 110 watts
Output Power (14.4V) 4 ohms Bridge 2 x 210 watts
Frequency Response 15 Hz - 40,000 Hz
Total Harmonic Distortion <0.05%
Signal to Noise Ratio @ 100Hz >80 dB
Input Sensitivity 250mV - 6V
Dimensions (W x H x L) 10.51" x 2.56" x 13.78"
Retail: $449.00. Asking $200, 2 of them for $375. Amp kits available as well as install
Any accessory you want are available. Any boxes, wires, fuses, distro's, anything you need I can get you.
Contact Info:
AIM: ATLspaced
Email: [email protected]
Feedback:
eBay Feedback
HeatWare
Founder of PsychoLemon CC
Brand new subs? I might take a pair. Sounds really nice. Where are u located at? And what would shipping be to commerical 30068.
1 - 4 of 4 Posts
