1 - 7 of 7 Posts
Everything came off a 98 4dr 4cyl MT accord with 40xxxmiles!!
1. 5 speed transmission (40xxxmiles)
2. 5 speed starter
3. 5 speed shifter assembly w/ shifter cables (f23)
4. 5 speed clutch pedal assembly
5. 5 speed brake pedal arm
6. Clutch master cylinder w/ reservoir
7. Clutch line from Clutch master cylinder to clutch dampener
8. Clutch dampener assembly
9. Clutch line from Clutch dampener to 5 speed tranny
10. Clutch line from 5 speed tranny to slave cylinder
11. Slave cylinder
12. Clutch
13. Flywheel
14. 5 speed mount
15. 5 speed mount bracket
16. 5spd ECU
17. Wire harness
18. ALL original bolts and screws
95% of EVERYTHING is there for the complete AT->MT swap!!! All you need is the intermediate shaft and driver's side axle which you can pick up for 140 at any autostore like pepboys or autozone!
PRICE: 650+SHIPPING FOR EVERYTHING!! I picked it up from a local junkyard for 780-800ish (which is still a really good deal, I PROMISE you, you won't be able to find for cheaper, COMPLETE AT->MT swap!!)
Discussion Starter #2
ttt, somebody with 4cyl AUTO PICK THIS UP!!!! or somebody that wants to replace their 4cyl manual TRANNY!!!
still sitting pretty in my garage!! 650 pick up or 650 +shipping.....need it gone! everything is there exactly the way i purchased it from the junkyard!!! will not part out!! if serious, call me at 2063558627
1 - 7 of 7 Posts
