1 - 8 of 8 Posts
***1 owner j30a1 engine 120k***
*Timing belt, water pump and seals done at 95k
*J30a1 engine. Runs great (no j30a1 intake or fuel injectors)
*Thermal block head to runners gaskets
*J30a1 TB, alternator, starter, ac compressor
*J32a2 intake (needs to be port matched to use on j30a1 engine)
*J32a2 270cc stcok injectors (fuel rail needs to be modified to use on j30a1 engine)
*Ingalls stiffy torque dampner (only used for approx. 10k) new its $150
***$375***
*Will part out*
This engine is ready to drive or you can use it as a project build while you drive your car. Its been out of the car for about 2 months. Went w/ a j32a2 motor swap so dont need it anymore. I bought the car new and have been the only owner so its been kept up w/ on maintenance.
Thanks,
Brad
941-740-0255
Bro honestly your not going to get much for the j30 motor, trust me i tried when i replaced my j30 with one from a junkyard. It's a motor nobody really wants. Your probably better off parting the motor out
Yeah, your probably right. It would be a good project motor to build so you dont have down time by building the motor in your car.
1 - 8 of 8 Posts
