I ♥ My Honda
Bought this for my laptop but it died before i finished my carputer setup. Going with a custom built rig now so wont be needing a laptop cooler :) Used for maybe 10 mins runtime.
Asking $20 shipped vis USPS PRIORITY.
This is a compact laptop cooling pad, with two functions (Cooler and Hub) combined. There are two powerful and quite fans of size 70 x 70 x 15 mm built in which absolutely helps to dissipate the heat-air away from the laptop to cool the overall system down.
Besides its cooling function, the unique cooling pad has a built in USB 2.0 4 port HUB. It can be easily expanded into four more high speed USB ports (480Mbps) to your laptop. The USB hubs can be used with most low-power USB peripheries, such as USB mouse, USB keyboard, USB web camera, and USB sound card.
Product Features
# Slim and smart design of the cooling pad system with two large, high performance, and extra quiet built-in fans that dissipate hot air away.
# Built-in 4- Port USB 2.0 Hub to expand your USB usage on your laptop.
# Uniquet design, Foldable floor so that the smaller size, convenient,and comfortable to carry.
# Ergonomic designed angle for easy typing.
# Extremely heavey-duty construction of the cooling pad to afford any weight or pressure put-on.
# Power management feature (on/off button to turn off fan).
# Fans and hub can operate independently.
# No adapter necessary,powered by USB power.
# Compatible with All laptops/notebooks.
Specification
# Device Type: 3 Fans USB Cooler Pad.
# Interface Type: USB.
# Air Flow: 28 CFM.
# Speed: 1500 RPM.
# Noise: 25 dBA.
# Voltage: 5 V.
# Power: <=0.9 W.
# Rated Current: 180 mA.
# Fan: 2 PCS 70 x 70 x 15 mm.
# Dimension: 11.8" x 6.1" x 0.7" (300 x 155 x 20 mm) / Max size: 11.8" x 10" x 0.7" (300 x 255 x 20 mm) .
# Weight: 19.4 oz (551 g).
# Color: white.
PLEASE PM ME OR CONTACT ME VIA AIM (ephyouckay)
