1 - 2 of 2 Posts
250 x 1 Watts RMS continuous power into
4Ohms with less than 1% TH+N from 0-250Hz +- 3db
500 x 1 Watts RMS continuous power into
2Ohms with less than 1% TH+N from 0-250Hz +- 3db
Features:
Class: B/D
Channels: 1
Per Channel Power:
250W x 1 @ 4 Ohms; RMS @ 1% THD
500W x 1 @ 2 Ohms; RMS @ 1% THD
Total Power: 250 Watts RMS
Crossover:
HP 50-250Hz 24dB per Octave
LP 50-250Hz 24dB per Octave
Bass Control - 0-18dB @ 45Hz
Signal Input: 2 Low Level RCA(pr) Type
Line Output: 1 RCA(pr) AP Fixed Level
Power Input: Block Connector 4 Gauge Wire
Power Supply Topology: MOSFET/Unregulated
Output Topology: MOSFET
Display: LED; End Mounted
Heatsink: Cast
Protection: Thermal, Short, Overload
Wired Remote Control Included
Stereo/Mix Mono
Good amp in good condition. It works great I'm selling this for a friend, but I was there when it was pulled out.
200 ish range.
1 - 2 of 2 Posts
