1 - 11 of 11 Posts
Since there has been so many concerns with the alignment spec's once this kit is installed here is the answer from Honda. The car will not maintain its original settings.
User #4002
Are the original settings on 6th generation the same on the original 7th generation?
looking at the specs of camber on the 04 acord,
after install should u get a camber kit?
From what others are saying on this site its going to be a case by case situation. So far the kits we have installed, they all fall within specs given above. Some people have installed the kit and have been out of range so a kit was needed.
hey. so i just installed the S-techs and i got an alignment already. my rear camber is for the left is -2.0 and the right is -1.7. does this mean i fall within the specs for the HFP suspension and i dont need a camber?
Thanks
JoE
Discussion Starter #9
Thanks
JoE
You are within the specs set by the chart
1 - 11 of 11 Posts
