1 - 4 of 4 Posts
7th Gen ACcord
Discussion Starter · #1 ·
just wondering how do you remove the cover for the air filter on 7th gen 4 banger? in the manual, it says remove the 4 screws. i did that, but i cant lift the cover. do i need to remove anything else? thanks
wah?
are you simply trying to replace the filter or take the whole thing off?
if your just trying to replace it do this. unscrew the four bolts. now stick your hand under the fender area and pry a little to get it loose. then use brute force :)). its really simple, i had a hard time my first time but its really easy. hope this helps
7th Gen ACcord
Discussion Starter · #4 ·
thanks. im try to see how dirty is the filter. stupid honda for making everything hard to work with.
1 - 4 of 4 Posts
