pull out the black clips inthe trunk right behind where headlights are and pull back carpet. then look in behind the light from the trunk side and there is four nuts to take off (8mm i think) then you unplug bulbs and push taillight from inside while supporting and pulling from outside.
the center light has black plastic covers that bulge out in trunk pull these of (they just clip in) and remove nuts (8mm) there are several of them so hunt around a little:)
