Your V6P Snake Champion
DarkVillian said:
Rim size-19"
Offset-30mm
Rim width-8
Tire size-245/35/R19
would this fit a 2003 honda accord coupe?
This package will stick out an extra 1.8 inches under your fender. You may not have enough room. What is causing this problem is the 245 size tire... May I ask why you want to go with 245? 225/35/19 is the application most people use. Go with that application and you will be good as gold
EDIT: Are you dropped at all? If your not I would scrap the whole Idea of getting rims. Because if you arent lowered and you put those rims on there then ummm... You could take a nap in the wheel gap.
