1 - 2 of 2 Posts
I have 97 Honda Accord Ed Coupe and got some Indiglow guages, i would like to install them, can i get a quivk run through on how to do it. Thanx
Quick answer is, remove gauge cluster, tap positive and negative wires of dimmer and good to go.
Long answer is remove center console, remove shifter assembly, remove two screws above where radio used to be; remove two screws from top of where gauge cluster is......pull out a/c panel, then unscrew gauge cluster, then pull out and disconnect wires. then after that **** is done, then carefully put the faces on and tap the appropraite wires.
1 - 2 of 2 Posts
