1 - 8 of 8 Posts
Last week I went ahead and ordered precat deletes. I have been worried about my cats dissolving and shooting ceramic into my engine, and I also worried about the excessive heat the cats hold in the engine head, particularly since I live in SC where it gets stupid hot in the summer. Plus I drive 100 miles a day or more and I have heard these will help highway mileage. The added power is also a pleasant bonus.
As most have said, Richie provides awesome service. I'd highly recommend going with any of his products. He provides everything needed for the install and everything fit 100% perfectly. In addition he sent me a telescopic magnet tool, key chain, license plate frame and some RV6 stickers all for free.
Notes on the install:
I have heard people complain that these are really difficult to install. I didn't feel like that was the case, but if you don't have a ton of different tools I could see how it would be hard. I needed 10, 12 and 14mm sockets both deep and shallow, wobble adaptors, 3" and 6" straight extensions, an adjustable long handled socket wrench, and a shorter regular socket wrench. Luckily I also had access to compressed air and that definitely helped the cause, but it's not necessary. A breaker bar is also a must, and an O2 sensor socket. There's a pretty good thread over on Acurazine that has a step-by-step installation guide, and I followed it pretty closely and had no issues.
The back cat is far and away the hardest, but honestly it wouldn't have been that bad if the heat shield bolts weren't so ridiculously rusted. both heat shields need to be removed on the rear cat in order to take it out the top and I had to cut the heat shields with a dremel because the bolts were rusted to oblivion. And in order to get at the bottom heat shield bolts with the dremel, I had to unbolt the cat first and drop it down as far as it would go. It took over an hour to remove the heat shields on the rear cat. Once the heat shields were out on the rear cat it will lift right out the top with no issues.
Review: Engine runs a LOT cooler. I was able to grab a hold of my intake manifold after my 50 mile morning commute and that thing normally feels like a griddle. Also: I still have a completely stock exhaust bolted up to the precat deletes and I am getting virtually no rasp. I was really worried about rasp since I spend so much time driving a day. My fears were groundless. I get a bit of rasp on a WOT run but it's not unpleasant, and there is zero when highway cruising.
Power is definitely increased, the engine doesn't run out of breath at 6k RPM like it used to, and it is definitely faster throughout the powerband.
Overall I'd say it's a worthwhile mod - better gas mileage, car is more reliable, engine runs cooler, and the car is faster! And I'm still running a cat so the treehuggers can't crucify me.
Mr. Detail
Did you get a CEL after installing them?
Nope no check engine light. The precat deletes come with the O2 defoulers already installed in the correct position, although I had to move the front precat defouler a few degrees as it was hitting the front engine mount. but I am quite happy that there was no check engine as I've heard a few ppl having issues with that.
Also my ECU has had some more time to learn that my exhaust actually flows now, and I really notice the increase in torque in the midrange now. I'm about to do the timing belt and a valve adjustment next, and then hopefully no more maintenance mods for a while.
Mr. Detail
Thanks! We have emission testing here (can't have a CEL) so that's good to know.
Yeah that’s the benefit of no emissions testing in SC, you could drive a brand new car off a lot here, go straight to your garage and delete every cat on the vehicle, and run the car into the ground over the next 20 years and never get bothered. I’d think twice about installing these in a state that tests, but I’ve heard that as long as they are installed correctly and you keep the 3rd cat that there are guys that have passed both the OBDII test and the sensor-in-the-tailpipe test with precat deletes installed. Totally catless guys have passed in states that just do OBDII.
Personally if i was in Cali or some super strict state id pass on these. I’ve hear of guys that re-install the regular cats just for testing but if you ask me that’s way too much work, and aside from that if you pulled cats and deletes on and off the exhaust studs enough, eventually you’d break one and be in a world of doodoo.
Mr. Detail
I pass with my other car with zero issues here and it doesn't have any cats. Also doesn't have a CEL so that's all they check.
Ok so installing the Cat deletes has given me the mod bug. Here's a question for any of you posters still active: what gains are there still to be made in the exhaust if I still have a stock j pipe, 3rd cat, and catback? I've heard some people say once you delete the precats, there's not a ton of gains still to be made..
Mr. Detail
Long tube J-pipe definitely helps, the stock one is a huge restriction. Side by side you can see the difference between stock and the XLR8 v2 J-pipe.
1 - 8 of 8 Posts
