1 - 9 of 9 Posts
hey guys im looking into some new rims,
will these fitments be fine with tein basic coilovers and camber kits?
18X8.5...what offset?
19X8.5...what offset?
rubbing issues?
anyone on here running this setup?
thanks
neeeeeeeeeeeeeeeeeeeeeeel
to be on the safe side you can get a 45 offset or higher.. rubbing issues depend on how low you are and stuff so.. are you going to slam it or?
well i dont want any wheel gap...if i have to maybe 1 finger gap
than you should be fine.. .. when you lower it just get a rear camber kit!
oSCaR
nighthawk04v6 said:
youll be fine with a 45 offset can't go any wider than 8.5 without modifications.
mQike ran 9.5's iirc w/ his last volks (GTC's I think). He wasnt slammed though... I think finger gaps all around.
Like everyone else said... if you have a coupe you should be good with et45... you'll be cutting it close but it can be made to fit w/ very minimal camber if needed... or folding the inner fender lip up and youll be fine no problemo too.
or you can run a 50 offset and youll be gravy... and youll be able to run fatter tires to protect your wheels/lips.
azndawgg said:
how about a 18X8 and i already have a 2 inch drop? what offset would be fine??? on an accord coupe 02??????
i had 19X8's, go with +45 or higher and youll b fine
i had 235/35's
Discussion Starter #9
anyone dropped on teins that had to get a front camber kit???
1 - 9 of 9 Posts
