I have a j35a6 block and intake manifold i was wondering if my j30a4 heads will fit?. Due to j30 has hole in the block. Pkease lmk thank you
Yes. It will raise your compression for the j30 head has a 86mm combustion chamber j35 head 89mm combustion chamber which is from my math 4cc less in volume. With that said I’m currently running ported j30 heads on built j35 block.
Sent from my iPad using Tapatalk
2004 Honda Accord EX Coupe 6 - 6
Would a J37A1 heads work on a J35a6 block?
i assume if I had a choice between J30A4, J35A6, J37A1, The J37A1 head would be better overall on the J35A6 block?
