1 - 9 of 9 Posts
Hickam Series
J32a2 Pauter Rods. $800
02 TL Type S automatic longblock with wire harness $750
04 TL Type S manual trans with LSD with new slave cylinder
cgi.ebay.com/ebaymotors/160616274512
Upper Intake manifold and throttle body off 03 tl type s $200
Hasport EGJ2 mounts with 90a urethane $450
J32 Swap Hasport Axles. $275
J32 V6 Automatic Halfshaft (This IS the one you need for swapped cars) SOLD
K series Hybrid Racing shifter... SOLD
Fuel rails. -6an and -8an welded fittings on each side $150
(2) Rota 15x8 with +26 offset. Very hard to find rim and hardly ever in stock. Can run these without spacers with a 235/60-15. Satin black and 4x100. $250
5 LUG 5x114.3 type R 36mm spline. Front only $300
EG/DC Blox orange anodized rear LCA $75
Skunk 2 EG/DC front camber kit $100
92-95 EG Exospeed front. $650
RSX Subframe. $150. STRAIGHT!
RSX manual conversion. Slave cylinder and pedal assembly $100
RSX Power steering rack $100
RSX Tan door panels, just need cleaned $75
RSX Front calipers $150
02-04 RSX Interior wiring harness $200 for all
RSX Fuel tank $75
Headliner $50
ABS Module $75
K sport EG/DC coilovers. One of the fronts needs rebuilt. $600
Tokico Blue with H&R springs Low miles, still on car. $500
Selling silver carbon fiber hatch and duckbill from EG also including a silver anodized diffuser. Asking $600 for all
Haltech platinum 2000 w/ flying lead harness brand new in box
Everything untouched and ready for new home $1800
AEM K series fuel rail. $125
Selling my k-tuned kit. Only has 100 miles on it. Has -16an hose ends welded to it. There is a -8an line from waterneck to housing. water temp sensor for gauge cluster and fan switch are both included and installed into the housing.
$250 OBO
K20a2 harness. Was running this on my turbo setup and should be plug and play for your setup. Has the obd1 injector clips wired in. The thermostat and fan switch are wired in to run to the K-tuned thermostat housing. GM 3 bar map sensor wired in and included (no more stock sensor). Honda resistor box wired in and included. The Knock sensor and alternator wiring is in this harness so you dont need a jumper harness. All you will need to do with the jumper harness is positive and negative for alternator and starter. $300 OBO
Custom K series catch can
Orange valve cover with -10an bungs
Comes with (4) -10an lines to valve cover
$400
HKS EVC (5 or 6, not sure which one it is) boost controller/gauge
Digital read out, had it in my car for a while and it works great but using boost by gear so i dont need it anymore
Needs the power plug, Should be no more than $15 from HKS dealer
$350 OBO
Blitz FATT DC turbo timer
works great
$75
DC sports rear lower tie bar
fits EG/DC
$75 shipped
Neuspeed EG/DC strut bar. Should kit EK also
$100
Ofna Hyper 7 brushless 1/8 buggy
Feiago motor with LMT/BK esc. Can handle 16s lipo battery or 20-21 volts of POWA!!
This thing is WAAYYYY faster than the nitro buggy!
$300 OBO
Ofna Hyper 7 nitro buggy. Lots of carbon fiber and nice parts.
$350 OBO
3" Stainless braided FLEX PIPE
Brand new
$50
Volk NRs 15 x 6.5 with a 43 offset
They have brand new with the stickers still on them Falken 912
One of the rims still has a customs sticker on it from Japan, they stopped making these wheels in '96 or somwhere around that year. $950 OBO without tires. Can powdercoat them a different color for another $150 if interested..
Pic of my friends car they were on in Japan.
Type S box, sold the cables
$50
Looked like a cool project, why are you parting it out?
Is it an 04 base TL 6spd tranny? Mileage?
I don't think there was a type s in 04.
03 Accord 6/6, 09 Audi A4
what size is the engine on the Nitro Buggy?
1 - 9 of 9 Posts
