Discussion Starter · #1 ·
I am new to the tuning scene so I'm a noob.
I'm having a little bit of an issue about the turbo oil feed, so there's this four-way adapter that's the universal kit comes with, but this doesn't look right the timing belt tensioner is in the way and to make it worse the Vtec solenoid is even more in the way, how do I combat this problem? all I see is two scenarios 1 I would have to have some sort of 90 degree angle??? adapter to offset the four-way adapter or scenario 2 I go with the aem ecu with the aem oil pressure system and hook it up through can bus through it.
I just need a little bit of help with this if somebody has done it 10 times better.
Automotive tire Wood Gas Motor vehicle Metal
