Well this build will be continuing from my flashpro dyno thread which I never finished. I had the chance to get hold of a 85k 2006 3.2 Tl motor(for only $595) anndddd so I did!
I will complete the dyno after I clean, build and swap this motor in, probably in 3 weeks or so. Trying to get a hold of Type S heads or MDX heads but can only find the front bank, otherwise I'll just get type s cams. So if anyone has any cylinder heads of this sort, lemme know!
I'm stuck right now on getting the crank pulley bolt out so I can get the timing cover off. Impact isn't doing it, I'll try heat and later the 50mm crank pulley socket if heat doesn't work.
Mmmm so clean
Mmmm so clean
