Discussion Starter · #1 ·
i purchased a Ktuner and received it few days ago. i need some assistance as far as some of parameters go. I have tried on Ktuner.com forum but no help .
Q1 I have EGR delete kit. if I click on EGR valve flow, under monitors on the right for EGR system, does this disable my EGR? can I go ahead and install my EGR delete kit?
see pics below
Q2
Before I uploaded the tune. Ktuner was reading and showing different value readings on STFT & LTFT like -8 to +5. after i checked the box for O2 all it shows is LTFT at 0 and STFT at 100%. is this normal? also my AFR was moving around different values., now it is stuck on 14.7 . is this because I disabled O2s?
thank you in advance.
Rectangle Screenshot Font Line Parallel
