1 - 10 of 10 Posts
I am selling 2-JL Audio 10w0's and 1-JL Audio 300/2 amp with a generic digital farad cap in a carpeted box for $400 OBO. Everything is in very good condition and I haven't abused the subs. I am located in Walnut Creek, and you can contact me via PM, e-mail at [email protected] or via AIM at aznboyiceyice. I am selling this because I have run into some financial problems and I need to get out of it ASAP. Thanks for looking.
tytyguy said:
i will buy the w0's for 90.
I'm trying to avoid shipping and since the w0's are already sealed in a box, the size would make it difficult to ship and shipping charges would be a lot, but if nobody local wants to buy the subs, then they're yours for $90+shipping, but it's always negotiable.
five0netvv0 said:
can you post specs of the amps?
Specs for the amp were found from jlaudio.com
Specifications:
Rated Power (stereo):
150 W RMS x 2 @ 1.5 ohm-4 ohm
(11V-14.5V)
Rated Power (bridged):
300 W RMS x 1 @ 3 ohm-8 ohm
(11V-14.5V)
THD at Rated Power:
<0.03% @ 4 ohm
S/N Ratio*:
>108.5 dB below rated power
Frequency Response:
5 Hz-30 KHz (+0, -1dB)
Damping Factor:
>200 @ 4 ohm per ch./50 Hz
Input Range:
switchable from 200mV-2V RMS
to 800mV-8V RMS
Dimensions:
13.4"L x 9.25"W x 2.36"H
Features:
Differential-Balanced Input Topology:
(1 pair of inputs)
On-board Crossover:
fully-variable (50 Hz-5 KHz),
selectable-slope LP or HP (12 or 24 dB per octave)
Preamp Output:
2-channel (full-range, LP or HP)
Speaker output connections:
accept up to 8ga. wire
+12V and Ground connections:
accept up to 4ga. Wire
1 - 10 of 10 Posts
