Description: Dimensions:
Frame Diameter: 10.5 in. (267 mm)
Mounting Hole Diameter: 8.74 in. (222 mm)
Mounting Depth: 8 in. (203 mm)
Overall Depth: 9.63 in. (245 mm)
Magnet Diameter: 6.55 in. (166 mm)
Pole Vent Clearance: 0.75 in. (19 mm)
Displacement: 0.09 cu. ft. (1.78 ltrs)
Enclosure Recommendations:
Sealed Range: 1.00 - 1.375 cu. ft. (28.3 - 38.9 ltrs)
Recommended Sealed Volume: 1.25 cu. ft. (35.4 ltrs.)
Fc: 44.7 Hz
F3: 40.7 Hz
Qtc: 0.785
Ported Range: 1.125 - 1.5 cu. ft. (31.9 - 42.5 ltrs)
Recommended Ported Volume: 1.5 cu. ft. (42.5 ltrs)
Recommended Tuning: 32 Hz
Port Type: “Slot” ports are recommended. See Data Sheet for detailed info.
Car subwoofer Subwoofer Vehicle audio Loudspeaker Audio equipment
Discussion Starter · #2 ·
Excellent speaker. 750 watts through it with a Zapco AG750 amp, and it just wants more power. The only complaints I have are the weight and the price. Heaviest speaker I have ever had, but if you can afford it and don't mind having the extra weight in the trunk, IMO there's no better sub on the market today (except maybe the 12w7). Crisp, clean bass, and incredibly LOUD.
Rating5
ProsClean, sharp bass notes. Durability.
ConsWeight. Price.
Would you recommend?yes
