1 - 20 of 51 Posts
Vimal (vee-mall)
Hey guys, Well im doing my first ever system build in my car and thought i'd show some progress pics so far. I decided to keep my stock headunit to keep the stock look inside. no matter how cool a an aftermarket headunit is, i just cant get over the fact that they come with stupid layouts, retardedly small buttons and text, and imo ugly faces, no offense to those of you who like that stuff, its just not my cup of tea. the ones i do like happen to cost close to a grand so that's not gonna happen. anyways, here are my system specs:
Infinity Kappa Perfect 6.1 component speaker (front doors)
Infinity Reference 9613i 6x9s (rear deck)
Infinity 475a 4ch. Amplifier 75watts x 4 @ 4ohm (for the front and rear speakers)
Infinity 1600a mono Amplifier 400watts x 1 @ 4ohm (for the sub)
JL Audio 13W3V3-4 13.5 inch Subwoofer
Custom built and designed enclosure
Second Skin Damplifier on doors and rear deck and trunk lid
Removed 3rd brake light (i have a spoiler)
Reupholstered rear deck with black fabric
wires:
KnuKonceptz 4gauge for power and ground to the amps
KnuKonceptz in-line fuse 150A
KnuKonceptz distribution block to split the power cables to each amp.
16gauge for the 4 speakers and tweaters
12gauge for the sub and its amp.
most of my parts have not come in yet, they're coming in late next week and next weekend, i'll start building my box with my friend, then a couple days after that, i'll install the equipment and get to tuning it.
Here are a few pics for now, i'll update pics as i do more stuff
In these pics, what i've done so far is just remove the necessary panels, clean up a bit, and i've also laid out my speaker wire for the front doors and installed the crossover boxes. one crossover box is under the driver side footwell and the other is inside my glovebox so that means i have 2 pairs of speaker wire running into each door.
my sub box specs: (i am going to make the box about 1.5inches deeper than what's labeled in the pic)
Planned layout/design:
NOTE:** all pics of the box are drawn to scale, there is about 1.25-1.5in of gap between the edge of the sub and the edge of the plexi.
I have to give MAJOR PROPS to NexsoN! He's been teaching me everything i need to know for this build and has been guiding me in the right direction since the beginning. THANK YOU!!!
many more pics to come as i do more work. stay tuned!
-Brian
Hey, It is great to finally see pictures of what we been discussing heh
This coming week is going to be crazy with all those shipments! Can't wait for more pics!
lookin good so far! hope you like the infinity speakers. we'll def plan something at the end of april or early may to show off our systems.
keep posting pics
Vimal (vee-mall)
does anyone make tweater pods that go in the triangular panel by the mirrors? i think they're called sail panels. i'd rather not cut a hole into my door panel.
Guess I'll join in on the fun. I have zero experience with audio installation so I left it to the experts. I'll be picking my car up ...thursday hopefully.
more pics vimal!
Vimal (vee-mall)
ok, here you go...
my parts pile (stereo equipment hasnt arrived yet)
my reupholstered rear deck, black fabric.
well today i did a couple things, i applied a 1/2inch layer of foam to the entire trunk in between the sheet metal and the trunk liner to keep it from hitting the metal. (sorry, forgot to take pics of that) so now when i hit pretty much any area of my trunk, no more metal contact. i bought 2 large sheets of foam from a fabric store, cost about 20 bucks. i also bought my black vinyl material today for the face of the enclosure (you can see it folded under the papers in the pic). I also fitted the rear speakers and they BARELY clear the trunk spring, theres maybe 2mm gap. so it looks like i get to keep my trunk springs :) and i attached a few of the speaker connectors on the cable ends. pretty much all i did today.
hopefully my Second Skin Damplifier will arrive tomorrow so i can start applying that to the deck and the doors. I think my sub is coming tomorrow to, or maybe Wednesday.
Vimal (vee-mall)
Discussion Starter #12 (Edited)
tweeters installed...
edit: it looks like my specs for the sub box are way off because i took some more detailed measurements today and found several obstacles that i have to work around. im currently redesigning the shape of the box, but the layout will still be the same. the shape is going to be much more complex than i originally anticipated. stay tuned for the updated specs.
i may end up removing the rear center seat belt because the plastic holder thing in the trunk under the rear deck is getting in the way and since i RARELY... more like NEVER carry 5 people in my car, im not gonna miss it. or i just had a better idea, i'll somehow convert that rear center seat belt from a 3point shoulder belt to just a simple lap belt.
Vimal (vee-mall)
Discussion Starter #13 (Edited)
i spent all day yesterday pretty much redesigning my sub box and building a mock-up from cardboard and im glad i did because now everything fits just like i want it and all i gotta do i create a mock-up of the beauty board (the good looking part) and then transfer all these cardboard pieces to wood and build the actual box this weekend.
Walmart posterboard x2: $8
Elmers glue: $.99
Painters Tape: $5
Knowing exactly what my box will look like and how it'll fit before actually building it: $PRICELESS
pics:
the large pieces of white paper on either side of the sub are my mock-up amps, clearance is real tight.
nice tight fit against the rear seats...
barely clears the trunk spring and the rear speaker magnets...
and look at all that wonderful trunkspace that i still have :D
Mono AMP, and SecondSkin Damplifier are coming Thursday as well as all my power cables and accessories. 4ch AMP is coming Friday as well as the woofer grill. Sad part is that even if i finish my box build and install all equipment this weekend, i cant power it up until Monday night because my line out coverter box (LOC) wont be here till Monday :( its gonna drive me nuts to have a fully assembled system in my car and not be able to turn it on :cry:
Boosted
damn thats gonna look nice and clean. but make sure you the airspace is up to that w7 specs or itl sound like crap.
Vimal (vee-mall)
Discussion Starter #17 (Edited)
actually im not using a W7, im using a 13W3 and yea, the JL specs say 1.5cu.ft of airspace, their recommended dimensions are W16xH16xD14.75. if you take those measurements and adjust them to the shape of my box, i have more than enough airspace.
my box specs are rougly like this:
32 inches wide
11 inches deep at the base 6inches deep at the top. that doesnt include the about 3.5" in baffel that the sub is going to sit in, so theres a little more airspace too.
assuming my box didnt have that wedge shape in back, assume my box is W32xH14.5xD6
according to the JL specs(16x16x14.75)
if you take the 14.75 inch dept and lower it to my shallowest spot (6inches) and add the difference to the width, you end up with 24.75x16x6. then you take the 16" height and bring it down to 14.5 and add the difference to the width again, and you'll get 26.25x14.5x6. with those specs i still maintain the required volume but remember my box depth isnt actually 6 inches all the way, only at the top at the base its 11. then add in the fact that i have a 3.5" protrusion in the center where the sub sits, thats more airspace. then add in the fact that my box is nearly 6inches wider than it needs to be and i've got plenty of airspace even after i add in the huge woofer and the support braces. i probably have more enough airspace for a W7 but since im only running a W3, i'll be fine... i hope. plus my box is going to be filled with polyfil to help too.
Is there a drawback of having too much airspace? if so, its an easy fix, i'll just put in a divider inside the box, that will shorten the width a bit while maintaining the exterior dimensions.
when i first started researching this car audio stuff, i didnt know anything about anything but talking with NexsoN has gotten me pretty smart in the car audio stuff relatively quickly. again... THANKS NexsoN!
-Brian
Hey! Yup a w7 box would have to be almost the size of your trunk heh. Anyhow in regards to your IM you sent me. The amps will be on when you turn on your car. You have to tap your remote wire to a 12v power source. For me I tapped mine into an empty slot in my fuse box, but you have to make sure they amps turn off once you shut down the car. For some reason some power sources run while the car is off and will cause your amps to still be on, thus draining your battery. Kinda trail and error, but must go off when the car is shut down.
So hit me up on AIM when you get to that part if you need further assistance.
Anyhow, the mock up box is looking great, just the way I thought it up in my mind!
loooooookin good. You are making very nice progress on your build. Time isn't going fast enough for me. I hope that my build is on schedule and will be ready 2m.
Vimal (vee-mall)
Discussion Starter #20
new pictures of work i did ALL day today, literally from 9am to 6pm with breaks every now and then... im exhausted and still not done.
Second Skin Damplifier installed along with new speakers. foam padding inside the doors to help with unwanted noise and vibrations.
some parts that came in yesterday and today...
Damplifier going on the rear deck...
rear deck and new speakers installed, no more seatbelt, no more 3rd brake light.
Door panel and trim pieces reinstalled, nothing visible :)
Sub-remote:
more wires in the trunk:
i still havent gotten around to putting Damplifier on the trunk lid but that's tomorrows project. Hopefully sunday i'll start building the box with my friend but i havent been able to get in contact with him so who knows.
1 - 20 of 51 Posts
