My display clock is now about 1 hour and 5 minutes slow; now that daylight savings time is in effect. The clock was right on, before the Saturday time change.
I went into the diagnostics (holding menu+map+cancel for 5 seconds) and the H/U TIME SEND is stuck at "0:00"; any adjustments don't work here either ( the SET (bright yellow) just sits there when pressed and doesn't appear to send anything).
DST is set to ON
The diagnostic two NAV times some how both read to "2001.08.21 23:05:51" (or something near that, but 2001 is the year!) and although i could try reseting them by changing the hour + or - ; This would take an eternity do, so I refrained from setting them more than a couple of hours (and then settng them back).
Anyone figure out this bizarre time puzzle yet?
Hi there. I have the exact same problem as you! It started a few weeks ago... I noticed that the clock was running about 3 minutes fast (which is wierd because it always perfectly accurate). I removed the battery for about 20 minutes so it would reset, and when it did reset, the time started at 1:00. And yes, under the diagnostic, my time reads the same as yours, 2001.08.21....
Maybe if we put our brains together, we can figure this out.
