1 - 19 of 19 Posts
Wierd sound wonder if anyone knows how to fix it
Alright guys I have a 03 Honda Accord v6 mt with the following mods V3 PCDs, RV6 J-Pipe, Magan Test pipe 2.5" (third cat delete), big Magnaflow resonator, 2.5"mid pipe to 2.25" exit to Magnaflow Mufflers. Getting this raspy/ricer sound from 2500 to 3500 here are two videos.. don't know what to do to fix it any suggestions? Do you guys think I have a leak?
frumaroll
nope thats just how its supposed to sound because your catless. get some redline vids in here too, sounds good.
I will my only concern is that the tone changes it goes from a deep tone almost like a 350z or g35 to like a little ricer and very raspy, then back to the a deep tone again thats why Im asking. I'll definitely post another video later with some redline in it.... by the way this only happens wen the car is being driven while in idle or revin doesnt have this problem
frumaroll
yes, it's the precat deletes causing that bro. When there is load on the engine it makes a different tone. but believe me thats normal, if you want it to go away, add another resonator and it will tone it down.
Mr. Detail
I'll bet a pair of turbo style mufflers would quiet it down a lot. Had to do that with the 4th gen I had. Header, resonator (still had the cat though) and a Magnaflow gave me a ton of drone at freeway speeds. Went back to the shop that built the exhaust and had them put a turbo muffler on it instead. Still had a mellow deep tone at idle but the drone was completely gone, you couldn't hear the engine anymore at freeway speeds inside the car and even when I got on it, my cold air intake was louder. Zero and I mean zero, rasp.
Turbo mufflers are pretty free flowing, not quite like straight through but way better than OEM.
Mr. Detail
Curious, how do you get around emission testing with no cats? Here they plug into your OBDII port and check for codes. Any codes, you fail. Do y'all use O2 sims or non-fouler extenders to pass?
FG4
thats how its supposed to sound. sometimes with the right throttle it won't do it.
If adding another resonator would make stop I might just do that. Well here in Miami we don't have emission testing so Im not worry about it but I do have a fouler for my O2's sensor and Im not getting any codes from the car.
Mr. Detail
If non-foulers will work, great. As long as I don't have any codes, thats what matters.
Discussion Starter #11
Thanks for the advice I'm going to check it out if doesn't work Im gonna have to put the cat back on this thing lets see...
Open for any other suggestions...
SFL AV6
Discussion Starter #13
I believe my hanger is good but Im gonna check it again I notice on another thread that there was question about it so hopefully is that... have you changed your hanger yet?
SFL AV6
Yea the hanger will appear to be fine, but the rubber area where the hole is located, u wouldn't be able to tell is cracked unless u pull on that area a little and see if there is play or have a bright light to see if rubber area is torn. It's hard to see cause that rubber area is all black
Ordered my new one today and it will arrive on Thursday
Discussion Starter #17
I see what you are saying maybe I'm just better off changing it just to nock that out the list of possibilities... how much was it for a the new one?
Discussion Starter #19
Sweet thanks for the part number Im going to try this first if it doesn't work Im adding another resonator... Ill be posting some new vid soon
1 - 19 of 19 Posts
