1 - 8 of 8 Posts
08 Altima Hybrid....
These are my ceramic puck discs from Spec. Both are Stage 3 but for different applications.
The used one has a sprung hub and works with solid flywheels.
The New one is rigid and works with the accord oem 6-speed flywheel.
The Spec pressure plate broke on me, but is built the same as the accord stock one.
So you should be able to keep the stock pressure plate if you want.
Used Spec stage 3 sprung hub $100.00
New Spec stage 3 rigid $200.00
will the new unit work with the stock 03 cl-s 6sp
It would work, but you really need a sprung hub with the CL-S.
The Stock Accord flywheel is sprung and the stock CL-S flywheel is solid from what I remember.
1 - 8 of 8 Posts
